Other Products
How to manage your Afrihost Plus+ benefits
Afrihost Plus+ comes with a range of benefits that can be applied to your products.
Don’t have an Afrihost Plus+ subscription?
You need to have an active Afrihost Plus+ subscription before you will be able to access the benefit manager. Signing up is quick and easy - simply read our How to sign up for Afrihost Plus+ article.
Follow the steps below to manage your Afrihost Plus+ benefits in ClientZone.
- Click on the ‘Other Services’ tab.
- Select Afrihost Plus+ and click on your Afrihost Plus+ account on the right.
- Now click on the ‘Manage Benefits’ button.
- In the Manage my Benefits panel you’ll be able to edit the following:
- 2-for-1 Topups
Select a Mobile, DSL or Fibre Account to enable permanent 2–for–1 Data Topups at any given point in the month. - Double Data
Select a Mobile, DSL or Fibre Account on which you would like to receive Double your Monthly Data Allocation. - Soft Capping
Select a DSL or Fibre Account on which your connection will be rate–limited instead of cut off when you reach your Data Cap. - Double Turbocharges
Select an Uncapped DSL or Fibre Account on which you’ll receive twice as many Turbocharge minutes each month.
- 2-for-1 Topups
- Once done, click on the ‘Update my Benefits’ button to save your changes.
Benefit alterations will only take effect on the first day of next month.
Important.
Not assigning benefits to any product does not mean that your Afrihost Plus+ subscription is cancelled/deactivated. You will still be charged for your Afrihost Plus+ subscription. Read our How to cancel your Afrihost Plus+ subscription if you'd like to cancel your subscription.
- How to manage your Afrihost Plus+ benefits
- 01:58
