Air Mobile
How to sign up for Air Mobile Data Only
Air Mobile Data Only is perfect for mobile Wi‑Fi devices and tablets. You can get month‑to‑month mobile data with a flexible Out‑of‑Bundle service.
Sign up for an Air Mobile Data only via the Website:
- Go to Afrihost.com
- Select the Air Mobile tab at the top of the page.
- Select ‘Air Mobile Data Only’ under Month-to-Month Packages.
- Scroll down to see the data only packages. Select the data package that suits you.
- Select ‘Sign Up Now’.
- Monthly data package sign-ups will be directed to the cart, ensure the package selected is correct.
- Select “Next Step”.
You’ll be asked to select a SIM option.
- I have an MTN SIM Card.
Select this option if you want to use Afrihost Mobile Data on your current MTN SIM card. - I need a New SIM Card.
Select this option if you want to get a new MTN-Powered Afrihost SIM Card. - I need a Device & SIM.
Select this option if you want to get a new SIM card and a Device.
- Follow the prompts of the SIM option chosen.
- Double-check your order in your Shopping Cart and click on ‘Checkout’.
- Select the delivery option you prefer and complete the details.
- Select your preferred payment method or add a new payment method.
- Confirm your order and Select ‘Complete My Order’.
Sign up for an Air Mobile Data only via the Order Form:
- Go to the Afrihost Order Form.
- Click on the ‘Mobile & Wireless’ tab.
- Now click on the ‘Air Mobile Data’ tab.
- Select your preferred Mobile Data package.
- Click ‘Next Step’.
- You’ll be asked to select a SIM option.
Select this option if you want to get a new SIM card and a Mobile Device.
- Follow the prompts and remember to double-check your order in your Shopping Cart.
- Click on ‘Checkout’ to complete your order.
Porting to Afrihost Mobile.
Visit our Porting Instructions microsite for instructions on how to port your current number to Afrihost Mobile.
- How to sign for Air Mobile data only
- 01:57
