Air Mobile
How to sign up for Air Mobile Monthly
Sign up for Air Mobile Monthly via the website:
- Go to Afrihost.com
- Select the Air Mobile tab at the top of the page.
- Select ‘Air Mobile Monthly’ under Month-to-Month Packages.
- Scroll down to see the packages. Select the Mobile package that suits you.
- Select ‘Sign Up Now’.
- Monthly package sign-ups will be directed to the cart, ensure package selected is correct.
- Select “Next Step”
- Select a SIM option.
- Port my Number.
Select this option if you want to port your number to MTN to use Afrihost as your Service Provider. - Get a New Number.
Select this option if you want to get a new Afrihost-powered MTN SIM card. - I’m on MTN Prepaid.
Select this option if you are on MTN prepaid and want to opt-in to the Afrihost offer
- Follow the prompts of the SIM option chosen.
- Once added to the cart, add an Add-on such as SMS bundles and sign up for Afrihost Plus.
- Double-check your order in your Shopping Cart and click on ‘Checkout’.
- Select the delivery option you prefer and complete the details.
- Select your preferred payment method.
- Confirm your order, Select ‘Complete My Order’.
Air Mobile Monthly packages give you month-to-month airtime and mobile data. You can also choose to add SMS bundles.
Sign up for Air Mobile Monthly via the Order Form:
- Go to the Afrihost Order Form.
- Click on the ‘Mobile & Wireless’ tab.
- Now click on the ‘Air Mobile Monthly’ tab.
- Select your preferred package.
- You’ll be asked to select a SIM option.
- Port my Number.
Select this option if you are on MTN prepaid and want to opt-in to the Afrihost offer.
- You will be presented with add-ons. You can choose to add an SMS bundle or add Afrihost Plus.
- Follow the prompts of the option chosen and remember to double-check your order in your Shopping Cart.
- Click on ‘Checkout’ to complete your order.
Air Mobile Monthly.
Visit our Air Mobile Monthly microsite to find out more about our month-to-month mobile voice, data and SMS offerings.
Porting to Afrihost Mobile.
Visit our Porting Instructions microsite for instructions on how to port your current number to Afrihost Mobile.
