glow-desktop glow-mobile glow-tablet bg-header banner pattern banner pattern
shape-left
Fibre Broadband
shape-right
How to sign up for Fibre via the Order Form
You can sign up for Afrihost Fibre via our Order Form, simply follow the steps below:
  • Go to the Afrihost Order Form.
  • Click on the ‘Pure Fibre’ tab.
  • Select ‘Pure Fibre’.
  • To check availability in your area, select ‘Check if I can get Fibre’ button.
  • You will be taken to the Fibre Coverage Map. Enter the address where you would like Fibre to be installed, select the correct address from the drop-down options and press Enter to search the map.
  • Click on the ‘Check Fibre Availability’ button.
  • Choose your preferred Fibre provider and fibre package. Click ‘Next Step’.
  • Complete the Fibre Line Location details for your installation. Under ‘Order Type’ select ‘New Installation’ or ‘Migrate my existing Fibre line’.
New Installation - There is no fibre line infrastructure installed at the premises.
Migrate my existing fibre line - There is a fibre line & ONT/CPE already installed at the premises and you want your line with Afrihost.’
  • Click ‘Next Step’.
  • Afrihost will supply you with a Wi-Fi router as part of your order. Select ‘Yes I need Wi-Fi’ or ‘No Thanks, I have my own’.
  • If you selected ‘Yes I need Wi-Fi’ You’ll be asked to configure your new router. Once done, click on ‘Add Details’.
  • Finally, you’ll be taken to your Shopping Cart. Click on ‘Checkout’ to complete the order.
Address Tips.
When signing up ensures the address is correct. Give the address that can be found on your municipal bill. Especially if residing in an estate or complex. You can add your plot ERF number in the notes section if you know it and anything else that will help installers identify your property, for example gate, house colour, objects outside to identify property.
Did you know?
You can also sign up for Fibre via the Afrihost website. Read our How to sign up for Afrihost Fibre article to find out how.
medium-image
How to sign up for a new Fibre installation
05:00
Afrihost Network Status
See the status of our broadband, mobile and hosting networks
For more details, visit our Network Status Page
ClientZone - just like magic
Manage products  .  Make payments  .  Check balances  .  Top up your account
Manage Products
Make Payments
Check Balances
Top Up your Account
