Fixed LTE
How to sign up for Fixed Wireless Pure LTE
At Afrihost, we don’t lock you into outlandish contractual commitments. All our packages are Month-to-Month and can be easily cancelled if you change your mind.
- Go to the Afrihost.com
- Select LTE at the top of the page, then select ‘Fixed LTE Wireless’ tab.
- Enter the street address where the device will be used and click ‘Check Coverage’ to see availability in your area.
- Confirm the address entered is correct and select ‘Next’.
- If you do not have coverage, you will be presented with an Interest Form. Fill in your details and we will let you know when Fixed Wireless Internet is available in your area.
- If you do have coverage, we will show you which provider has coverage of that area.
Select your preferred provider and click ‘Continue’.
- Select the data package you require monthly and click ‘Continue’.
- You will be redirected to the Afrihost Order Form.
- Confirm your data package selection is correct and click ‘Next Step’.
Read our article for more information on how the pro-rata discount works.
- You will be asked if you require an LTE router.
- If you do need an LTE router select ‘Yes, I need a router’.
- If you do not need an LTE router select ‘No, I have my own router’.
- For an LTE SIM only package, select ‘No, I have my own router’ and follow the prompts to complete your order.
- If you select to get a router you will be asked to enter the devices configuration details.
Enter the desired network details and click ‘Add Details’.
- Confirm the items in your shopping cart are correct and click ‘Checkout’.
- Before completing the order, you may be asked to either log into your ClientZone account (for existing clients) or sign up for a ClientZone account if you are a new Afrihost client.
- Follow the prompts to complete your order. Select your preferred delivery option.
- Select your preferred payment option, or add new banking details.
- To complete your order, check the box to accept the debit order agreement and agree to Afrihost Terms & Conditions.
- Click ‘Complete My Order’.
- Go to the Afrihost Order Form.
- Select the ‘Pure LTE’ tab.
- You will be asked to check coverage in your area. Select ‘Let’s check my coverage’.
- Enter your address in the search bar and select the correct address from the drop-down options shown.
- If you have coverage, click on ‘Sign Up Now’ to continue with the order process.
- If you do not have coverage, you will be presented with an Interest Form. Fill in your details and we will let you know once Fixed Wireless is available in your area.
- If you do have coverage, we will show you which provider has coverage of that area. Select your preferred provider.
- Select your desired data package and click ‘Next Step’.
- Before completing the order, you may be asked to either log into your ClientZone account (for existing clients) or sign up for a ClientZone account if you are new to Afrihost.
- Select your preferred payment option.
- How to sign up for a Fixed Wireless Package
- 04:11
- How to sign up for a Fixed Wireless SIM Only package
- 03:30
