Air Mobile
How to switch to the correct call rate
We suggest that you switch to either MTN Pay per Second or MTN Talk Free if you are not on the correct call rate. Switching to a cheaper call rate will help to avoid unnecessarily paying more for the calls you make.
You can change your call rate at any time by accessing the MTN Price Plan platform from your device
- Dial *136*4# from your device.
- When prompted, select Migrate Price Plan (Option 2).
- Select either MTN Talk Free or MTN Pay per Second.
If you would like to know more about the Afrihost Mobile Call Rate read our Help Centre article for more information.
You will remain on your current call rate. But please note that you may be charged more for calls than you would if you were on the suggested MTN Talk Free plan.
No worries! You can change your call rate at any time by dialling *136*4# from your device. You can confirm that you are on the suggested call rate by logging into ClientZone and clicking on the Mobile tab.
Please note that you are only allowed to change your price plan twice per day.
