Fixed LTE
How to view your Fixed Wireless data usage
You can easily see how much data you have left on your Fixed Wireless account in ClientZone.
Follow the steps below to view your Fixed Wireless data usage:
- Select your Fixed Wireless data package.
- You’ll be able to see how much monthly data you have left on the right hand side.
- Any topup data will also show on the right hand side.
Monthly data rollover.
You can find out more about when monthly data expires by reading our Fixed Wireless monthly data rollover article.
Ran out of Data?
You can easily top up your account if you run out of data. Read our How to top up your Fixed Wireless data article.
Telkom Fixed LTE data usage.
You can find out How to view your Telkom Fixed LTE data usage in this article.
- How to check your Fixed Wireless Data usage
- 01:12
