Fixed LTE
What speeds can I expect on Fixed Wireless?
You can generally expect speeds between 10 - 150 Mbps download speeds and 2 - 5 Mbps upload speeds.
Please note, however, that average speeds remain device and coverage dependent.
Uncapped LTE.Â
All Pure LTE Uncapped packages are subject to a monthly threshold of 1TB. Once you’ve reached your monthly data limit, your connection speed will be limited to 1Mbps for the remainder of the month.
