How to change your Huawei E5330 Mi-Fi device SSID name and password
- Turn the device on.
- Connect to the device from your computer.
- Open your internet browser and navigate to 192.168.8.1
- Log in to the device.
- Enter the default username and password:
Username: admin*
Password: admin* - Select ‘Log In’.
- Select ‘Settings’ on the home screen.
- Select ‘WLAN’ from the menu on the left-hand side.
- Then select ‘WLAN Basic Settings’.
- Under the WLAN Basic Settings page, change the SSID (WiFi Network Name) as desired.
- Update the WPA pre-shared key (WiFi Password) as desired.
- Select ‘Apply’ to save these settings.
What is an SSID?
Reconnect to your devices with the new access details.
How to create a strong password.
Use a minimum of 10 characters with at least one number. At least one uppercase character and one lowercase character. Do not include a username or your name in the password and at least one special character eg: =~_{]@^&...
