How to create a subdomain in CWP
You can create a subdomain by logging into CWP via ClientZone.
- Select the ‘Hosting’ tab.
- Under the Shared Hosting section, select your domain.
- Click on the ‘Website Manager’.
- Select the ‘Log into Website Manager’ button.
- Select Domains in the menu.
- Select ‘Sub Domains’.
- Select ‘Add a New SubDomain’ button.
- Complete the New Sub Domain details.
Domain: Enter the subdomain name
Path: Where to find the subdomain
Tick ‘Generate Autossl’
- Click ‘Add a New SubDomain’ button.
You will now see your new subdomain added to the List Of Domains.
Remember.
Any website files for your subdomain must be placed in the accompanying folder, which can be found directly under the ‘public_html’.
01:44
