How to view your DSL data usage
Your bandwidth usage is available via ClientZone - along with tools that help you to manage every single aspect of your Afrihost experience.
Follow the steps below to view your DSL data usage in ClientZone:
  1. Log into ClientZone.
  2. Click on the ‘Connectivity’ tab.
  3. Select your DSL package in the list on the right-hand side.
  4. In the product overview panel, you are able to view
    1. Data Statistics
      View your total account data allocation, the data that you’ve used and your average daily usage.
    2. Detailed Usage History Graph
      View your daily usage over the past 3 months.
    3. Data Links
      The data links section gives you a breakdown of your current data usage, rollover data, topups or special data allocations.
