What speed should I get?
There are lots of factors in determining the right package for you, we’ll ask you some questions about how you use the internet to help you make the best choice.
We’ve put together a great interactive tool to help you choose the right speed based on your usage needs.
Pick the most relevant answer for each scenario. Also factor in that each service or device you use simultaneously would be sharing your internet connection, so the more services and devices used, the higher your connection speed should be for the best experience.
After you make your selections we will suggest the speed applicable based on your answers to ensure you get the experience best suited to you.
Will I always get my maximum line speed all the time?
We provide the best internet experience we can. Unfortunately, sometimes this involves factors outside of our control, like the quality of the copper on your DSL line or high demand on your local Telkom exchange, as well as demand on our network. So while we’ll do our absolute best to give you the very best speeds possible at all time, performance may vary from time to time, depending on the factors mentioned as well as others.
Use our useful tool to see what Broadband Speed you should get.
