How to check your Mobile Data usage in ClientZone
You can easily check your mobile data usage in ClientZone.
Afrihost Mobile Packages
  1. Log into ClientZone.
  2. Click on the ‘Mobile’ tab.
  3. Select your Afrihost Mobile package.
  4. You will be able to see your current data usage in the ‘Bundled Data’ section and in the data usage graph.
  5. You can also view your data sessions by clicking on the ‘Usage & History’ button and then going to the Data Sessions section.
Mobile Data Packages
  2. Click on the ‘Connectivity’ tab.
  3. Select your Mobile Data package.
  4. You will be able to see your current data usage in the account overview panel.
Did you know?
You can check your Mobile Data usage on the go in our ClientZone Mobile App.
Used all your Data?
Data? Read our How to topup your Mobile Data article.
