How to configure the APN on your TP-Link M7000 Mobile WiFi device
An Access Point Name (APN) is a crucial setting that enables your device to connect to the internet. By configuring the APN settings, your device establishes a connection to the gateway of your carrier. We will guide you through the essential steps to set up the APN on your TP-Link M7000 Mi-Fi device to ensure that you enjoy uninterrupted internet connectivity wherever you go.
  • Press the power button on the device to turn the MiFi device on.
  • Connect to the WiFi network of the MiFi device.
Connect to the WiFi.
If you would like to know What is WiFi and how to connect to a WiFi network, please read our Help Centre article for further assistance.
  • Open your preferred internet browser (Google Chrome, Mozilla Firefox, Safari, Edge etc.).
  • Enter the IP address 192.168.0.1 in the search bar and hit ‘Enter’.
  • Enter the password to access the device and click ‘Login’.
  • Once logged in, select ‘Advanced’ from the options at the top.
  • On the left-hand side select Dial-up, then select 'Dial-up Settings’ from the dropdown menu.
  • Click on the 'Create' button to add a new APN profile.
  • Enter the following information:
    • Profile Name: afrihost
    • APN: afrihost
    • Authentication: None
  • Click the ‘Save’ button.
AirMobile SIM cards.
If you have inserted the white AirMobile SIM card (white) enter: ws.air.mvno into the APN field.
  • Click 'Yes' to set this APN as default.
You have successfully configured the APN. You may now exit the interface.
