What is WiFi and how to connect to a WiFi network
Get Fast Wi-Fi Now!
Sign up here for Fast Wi-Fi, enter your address to check the coverage in your area.
What is Wi-Fi?
Wi-Fi is short for Wireless Internet.
Modern ADSL, Fibre, Fixed LTE and Mobile routers /modems all have the ability to broadcast a wireless signal in order to enable the user to connect their hardware (computers/ printers/ cellphones) to the internet without a physical connection.
Wi-Fi technology uses radio waves to give users wireless high-speed Internet connections in an area. These areas, known as hotspots can be located in your home, a hotel, a restaurant and any other area where internet is available. 
The ability and process to connect to a Wi-Fi network is specific to the device you are using to connect; however, the principle is the same:
  • Enable the Wi-Fi function on the device.
  • Scan for nearby Wi-Fi Networks.
  • Selected the desired Wi-Fi network name.
  • Enter the Wi-Fi password and connect.
The difference between Wi-Fi and Internet
The internet is a network of computers and network devices that connect to each other, that can share and access information and communicate worldwide. The internet is a global network of cables, including ADSL, Fibre and wireless connectivity like 3G & LTE.
When you visit a website, your computer sends a request over these wires to a server. A server is where websites and other data are stored, and it works a lot like your computer’s hard drive. Once the request arrives, the server retrieves the website or information requested and sends the correct data back to your computer. All this happens in seconds.
Wi-Fi is used to send this data to a device wirelessly and not via hardware such as a physical cable.
How to connect your device to the Wi-Fi
Note:
Default Network Name (SSID) & Password can be found on a sticker under the router/modem.
Android
  • Open ‘Settings’ from the main menu.
  • Select ‘Connections’.
  • Select ‘Wi-Fi’.
  • A scan will be done for ‘Available Networks’ in your location.
  • Select your desired network name (SSID).
  • Enter the password to the network and connect.
iOS
  • Select ‘Settings’ from the home screen.
  • Select ‘Wi-Fi’.
  • Available networks will be displayed.
Windows
  • Click the Network icon (Radio wave icon), in the taskbar at the bottom right.
  • A scan will be done for ‘Available Networks’ in the area.
  • Select and connect to your desired network name (SSID).
  • Enter the password to the network name to connect.
Mac
  • Select the ‘Airport’ icon on the top Right (Radio wave icon) of the screen.
  • Select ‘Wi-Fi network’.
Once you have successfully connected, you can open your browser to confirm connectivity.
What is an SSID?
SSID stands for Service Set Identifier. It is the name of your Wi-Fi network.
Still need assistance?
If you need further assistance, please connect with our friendly support via Afrihost Help Support Channels.
