How to create an app using Softaculous in cPanel
Softaculous App installer is a tool that simplifies the installation of web applications and scripts on a web hosting server. It is ideal for clients looking to quickly launch websites and web applications.
Follow the steps below to create an App using Softaculous in cPanel.
Log into Website Manager via ClientZone
  1. Log into ClientZone.
  2. Click on the 'Hosting tab'.
  • Select your hosting package on the right-hand side.
  • Select ‘Log into Website Manager’.
  • Scroll down to the Software section of the page and select ‘Softaculous’.
  • You will now be able to see all the Apps that Softaculous offers.
You have successfully located the Softaculous Apps Installer.
Install WordPress.
If you would like to read up more on How to install WordPress read this article for easy instructions.
