How to view your Telkom Wireless LTE data usage
Please note this will only work for clients with a Telkom LTE connection.
We understand that you would like to see an up-to-date balance of your Telkom LTE data balance, this is an alternative way to view your balance through the router if the balance has not been updated in ClientZone.
Huawei B525 USSD Code for data balances
  • Access the Huawei router via the default gateway.
    Enter 192.168.8.1 into the search bar.
  • Log in to the router, click ‘Log In’.
  • You may be requested to agree to Huawei’s Privacy Policy if it is your first time logging in to the device.
  • On the main home screen, select ‘Tools’ from the menu at the top.
  • Select ‘USSD’ from the menu on the left.
  • Enter the USSD code *188#
  • Click ‘Send’.
  • Wait while sending the USSD code.
  • You will be notified that you have received a response via SMS.
  • From the menu on the left-hand side select ‘SMS’.
  • Under ‘SMS Conversation’, click the response message to open it and view the available balance.
  • The response message will indicate your NightTime data balance and Anytime data balance.
Huawei B315 USSD Code for data balances
  • Log into the router. Enter the username and password and click ‘Log In’.
  • On the Home page, Select ‘USSD’ from the menu at the top.
Do not include anything in the body of the message.
  • Under ‘Check Services’ leave the message box BLANK.
  • In the command box below enter the USSD code *188#
  • Click ‘Send’.
  • At the top menu go to ‘SMS’ to see the response.
  • The response will indicate your NightTime data balance and Anytime data balance.
View other LTE data usage.
You can read our helpful How to view your Wireless Pure LTE data usage article.
