Where do I get my PPPoE username and password
PPPoE (Point to Point Protocol over Ethernet) is a broadband connection that involves data transmission and authentication (username and password). PPPoE is used by Afrihost clients that are on Openserve (DSL or Fibre line) and Vodacom (Fibre line) which connects you to your ISP to establish an Internet connection on Afrihost's Network.
Follow the steps below to obtain your PPPoE credentials:
- Select the relevant connectivity package on the right-hand side.
- If your package is not yet active please click on the 'View Product' button.
- If your package is active already, please click on the 'Access Details' button.
- Your username is displayed at the top of the panel, below your package.
- To get your password, click on the ‘Access Details’ button.
- Click ‘Reset Password’.
- In the success pop-up window, copy your newly generated password, save it and click ‘Okay’.
An SMS will be sent to the primary account holder’s contact number notifying of the password reset.
PPPoE configuration.
If you would like to know How to set up your TP-LINK EX511 Fibre Router for a PPPOE connection please read our Help Centre article for further assistance.
