How to check the Wireless LTE coverage in your area
Our LTE packages are only available in areas that have coverage from one of our LTE partners. Some areas have multiple providers, resulting in more choice and flexibility for you.
Check if Pure LTE is available in your area:
  • Enter the address where you will use the LTE connection to check the LTE Coverage Map.
  • Select the correct address from the drop-down options.
  • A pop-up map will appear, confirm the location is correct and click on ‘Continue’.
  • Based on coverage, you may be offered a choice of LTE providers or just one.
  • Select ‘View all available providers in your area’ below, to check for more options.
  • Select your preferred provider and package to continue with the signup.
You have successfully checked coverage in the area.
Sign Up for Pure LTE Now!
If you need assistance with How to sign up for Pure Wireless LTE, please read our Help Centre article for further guidance.
