Security
How to disable your Wi-Fi SSID broadcasting
What is SSID?
SSID stands for Service Set Identifier. It is the name of your wifi network.
What happens when your SSID broadcasting option is disabled?
All the wireless devices will not be able to pick up the wifi network.
Why should you disable SSID broadcasting?
You can disable the wifi broadcasting option to secure your network from attackers, this will prevent them from detecting your network.
Follow the steps below to disable the wifi broadcasting feature.
  1. Log into the router.
  2. Go to the wireless settings.
  3. Disable the SSID broadcasting feature.
Logging into a router:
You can follow these easy steps on How to log into a router.
Block users.
If you would like to know How to block users via MAC address filtering on your Fixed LTE router please read our Help Centre article for further assistance.
