How to perform a Traceroute and Ping
If you are experiencing poor network speeds, you may want to do a few tests to collect diagnostic data on the line.
Ensure you run these tests via a LAN cable and not the Wi-fi to get accurate results.
What is a Traceroute?
A traceroute is used to determine the path that a packet of data takes on the network from your computer to the source or address you are trying to reach.
A traceroute records the amount of time taken for each hop the data packet makes on route to its destination.
What is a Ping?
A ping test sends a small packet of data from your computer to the server and measures the amount of time it takes to get there.
This is done to see if there is any latency between the two devices.
How to Perform a Traceroute on Windows
  • Open the Start menu.
  • Click on Run.
  • Type cmd and then press the OK button to open a command prompt.
  • At the prompt, type: tracert www.afrihost.com and press the Enter key.
  • To copy the traceroute results from the command prompt, right-click on the MS-DOS window and choose Mark.
  • Then select the text with your mouse and right-click or press Enter on your keyboard to save the marked text to your clipboard.
  • Then you can paste it by pressing Ctrl+V into a text file or your email.
How to Perform a Ping on Windows
  • Click on Run.
  • At the prompt, type: ping www.afrihost.com and press the Enter key.
  • To copy the Ping from the prompt, please right-click on the MS-DOS window and choose Mark.
  • Then you can paste it by pressing Ctrl+V into a text file or your email client.
How to Perform a Traceroute on Mac OS
  • Launch Network Utility.
  • Click Traceroute.
  • Enter www.afrihost.com
  • Click Trace.
  • Select and copy the results.
  • Paste the text into a text editor (TextEdit, etc.) and save the file.
How to Perform a Ping on Mac OS
  • Click Ping.
  • Click Ping.
Latency Results
  • If the latency is on the first hop (to your router) it is probably a local network problem.
  • If the latency is to the second hop, then it could be Telkom exchange congestion.
  • If the latency occurs at the end of the traceroute, then it could be the load on the server you are trying to access.
When latency appears to suddenly spike is an indication of where the problem is. Try connecting with a different ISP account (or a different router) and see if the problem persists.
Also, for your router, disconnect all devices and switch the Wi-Fi off and then connect a single device to connect. Then try connecting devices one by one and see if one of the devices causes the problem, or if it only occurs when WiFi is brought back up.
Still need assistance?
If you need further assistance, please connect with our friendly support via Afrihost Help Support Channels.
