How to reactivate your Fibre line
How to reactive a Fibre line that is pending cancellation.
If your Fibre line status reads ‘Pending Cancellation’ this means our system has not yet fully terminated the line and can be reactivated up until seven days before the effective cancellation date.
  • Navigate to ClientZone and log in.
  • Select the ‘Connectivity’ tab.
  • Select your Fibre package listed on the right.
  • Select ‘Edit package’ button on the right.
  • Select ‘Reactivate Service’ on the right.
How to reactive a Fibre line that has been completely cancelled but still at the same address.
If the Fibre line status is fully canceled, you will need to sign up again for a migrate-in. Please follow the instructions below to sign up.
  • Go to the Afrihost Pure Fibre site.
  • Enter the street address where your fibre line is currently installed, select the correct address from the drop-down options.
  • Click the ‘Check Coverage’ button.
  • Select the fibre provider that installed your line.
  • Select your preferred Pure Fibre package and connection speed.
  • Select ‘Checkout’.
  • You’ll be redirected to the Afrihost Order Form.
  • Complete the Fibre address details.
  • Under the Order type field, specify that this is an existing Fibre line by selecting ‘Migrate my existing line’.
  • Click on the ‘Next Step’ button.
  • You will be asked if you need Wi-Fi. Select ‘Yes’ if you need a Wi-Fi router, and ‘No’ if you already have one. Once done, click on ‘Next Step’.
  • Finally, you’ll be taken to your Shopping Cart. Click on ‘Checkout’ to complete the order.
How to active a Fibre line at a new address with an existing CPE/ONT.
If you are a new client to Afrihost and have moved to an address that has a Fibre ONT box already installed on the wall and would like to sign up, follow the steps below:
  • Enter the street address where you would like Fibre to be installed, select the correct address from the drop-down options.
  • If there is more than one provider available in your area you can select your preferred Fibre network provider, however, if there is only one provider available it will automatically be selected.
  • Complete the Fibre address details for your installation.
  • Afrihost will supply you with a dual-band Wi-Fi router as part of your order. You’ll be asked to configure your router. Once done, click on ‘Next Step’.
Please keep an eye on your inbox - we’ll send you an e-mail once the line has been activated and migrated to Afrihost.
These times are an estimate and can vary. Line activation and connection times need to be added for full turnaround estimation.
Migrate over to Afrihost.
If you have fibre with another ISP and would like to migrate it over to us, please read How to migrate your Fibre line from another provider to Afrihost for further information.
