Air Mobile Airtime and Data top up rollover explained
AirMobile airtime and data top up rollover explained (Afrihost MVNO)
AirMobile data roll over
Top-up Data will only expire at the end of the FOLLOWING month. This means that if you haven’t used all of your monthly data by the end of the month, it will roll over to the next month. For example, if you buy 100MB and you have 50MB left at the end of February, the 50MB of data will roll over to March, to use until the end of March.
AirMobile airtime roll over
Airtime purchased within a calendar year will expire at the end of the following year. For example, if airtime is bought in 2024, it will remain valid until the last day of 2025.
You can easily top up your account if you run out of airtime or data. Read our How to top up your AirMobile data and airtime via the AirMobile App article.
Legacy Air Mobile (MTN)
Legacy Air Mobile Airtime Topups
Our airtime works according to standard MTN airtime rules. You get two different kinds of airtime - Evergreen and Expiring.
- Evergreen will stay active as long as your SIM card is kept from going dormant.
- Expiring airtime will expire at the date specified unless new expiring airtime gets added to your account - in which case all the expiring airtime will only expire on the new date.
All our Auto-Limit and manual top ups are Evergreen. Other types of top ups may however not be
If you would like to view your data and airtime balance in the Afrihost Mobile App, please read our Help Centre article for further assistance.
If you would like to check your Airtime usage in ClientZone, please read our Help Centre article for further assistance.
Legacy Air Mobile Data Top ups.
All data topups are valid from when they are purchased, until the end of the following month. This means that depending on when you buy a data topup, it could be valid for up to a maximum of two months.
For example, if you buy a data topup on 5 February, your topup data will only expire at midnight on 31 March - giving you even more value.
You can easily top up your account if you run out of airtime or data. Read our How to topup your Mobile Data or How to topup your Airtime article.
