How to upgrade or downgrade your package
To upgrade or downgrade your package in ClientZone, please follow the steps below:
- Click on the category (Connectivity/ Mobile/ VoIP/ Hosting) under which the product you want to change falls.
- Select the package that you want to change on the right-hand side.
- Click on the ‘Edit Package’ button.
- You can upgrade or downgrade your package in the ‘Change to Another Package’ section.
If you're running low on or have depleted your data you can easily add more by simply topping up your account.
When will my package change take effect?
Package Upgrades
A package upgrade is immediate and you will be billed pro-rata from the moment you confirm the upgrade.
Package Downgrades
Package downgrades take place at the beginning of the following month and you don’t get billed for any downgrade that you do. The new billing for the downgraded package will commence at the beginning of the following month. Make sure that your downgrade happens before our billing run.
Any changes done before the 15th of the month will take effect at the end of that month.
Changes done after the 15th of the month will then only be effective from the end of the following month.
Services cannot be changed if there are any outstanding balances on the account. The account must be settled first.
Please read our Help Centre article Will Afrihost swap over my existing DSL connection to my new Fibre connection once the Fibre connection is up and running, for more information.
Please read our Help Centre article How to change your Fibre package, for more information.
