How to set up your Fibre Connection (All other providers)
​These instructions apply to ALL fibre providers EXCEPT Openserve and Vodacom clients.
A DHCP connection is for all fibre providers whereas Openserve and Vodacom connect via a PPPoE connection.
Openserve and Vodacom clients, please read this article for assistance with How to set up your Openserve or Vodacom Fibre Connection in our Help Centre.
DHCP connects by obtaining an IP address and then connects automatically and should not require set up.
PPPoE connects via an ISP and requires a username and password.
1. Set up your Fibre equipment.
After the CPE /ONT box is installed on your property, you will need to set up your fibre router equipment.
What is the CPE/ONT?
If you would like to know What is a Fibre ONT/ CPE and where should it be installed? read our Help Centre article for more information.
  • Connect the ethernet cable from LAN Port 1 on the ONT device (The device installed by the fibre technicians) into the WAN/Internet port on your Afrihost fibre router.
    Ensure the CPE is powered up and lights are showing on the device.
  • Connect another ethernet cable from any of the LAN ports on your fibre router to your computer OR connect wirelessly to the router’s network (2.5 GHz or 5 GHz). The password can be found on a sticker underneath the router or on the welcome note found inside the box.
  • Plug the router power cable into the walls power supply.
  • The ethernet ‘LINK’ light must show on the ONT and the WAN light on your router. If these lights are present, it means that your fibre router is powered up correctly.
  • You will then be able to connect to the internet at 10Mbps for 2 hours in order to activate your fibre account.
2.4 GHz and 5 GHz Wi-Fi.
If you would like to know more about The difference between 2.4 GHz and 5 GHz Wi-Fi , please read our Help Centre article for more information.
2. Activate your Fibre account.
Once your router is connected to the ONT/ CPE, you will need to activate your fibre account.
Activate your Fibre now.
3. Connect to the internet.
Once activated, you should be able to connect to the internet as your router from Afrihost is pre-configured.
If you are struggling with getting connected, you may need to re-configure your router for a DHCP connection.
How to set up your Huawei WiFi AX3 WS7100 Fibre Router for a DHCP connection
How to set up your Huawei WS5200 Fibre Router for a DHCP connection
How to set up your D-Link 825 Fibre Router for a DHCP connection
How to set up your TP-Link EX511 Fibre Router for a DHCP connection
Change your (Wi-Fi) wireless network settings.
If you would like to know How to change your routers Wi-Fi password , read our Help Centre article for assistance.
