Vodacom Wireless LTE FAQs
Afrihost is no longer offering Vodacom Wireless for new sign-ups through our website. Existing Vodacom Wireless clients will remain on their current packages and do not need to take any action.
Frequently Asked Questions
What is Vodacom Wireless LTE?
- Vodacom Wireless LTE is an Afrihost LTE service that runs on the Vodacom network. It provides fast, reliable internet access without the need for a fixed line.
Why did Afrihost partner with Vodacom?
By partnering with Vodacom, Afrihost can offer:
- Wider coverage across South Africa.
- A cost-effective alternative to Fibre and DSL.
- Flexible data packages to suit different usage needs.
What packages are available?
Vodacom Wireless LTE packages include:
- Uncapped Anytime data packages.
This gives you the flexibility to choose based on your budget and usage patterns.
Sign up for a Wireless LTE package now and compare the packages available.
Do I need a new SIM card?
- Yes. To use Vodacom Wireless LTE, you will need a SIM card provisioned specifically for the Vodacom LTE network. Afrihost will supply the SIM card when you sign up.
Will my coverage improve?
- Coverage depends on Vodacom’s LTE network in your area. Since Vodacom has extensive nationwide coverage, most clients will experience improved availability and stability.
Can I use my existing router?
- If your router is LTE-compatible and supports Vodacom’s frequency bands, you may be able to use it. Afrihost offers compatible LTE routers for purchase.
- See below for approved list of compatible devices.
Who do I contact for support?
- All support is provided directly by Afrihost. Vodacom maintains the LTE network infrastructure, but Afrihost is your point of contact for any accounts, billing or technical queries.
If you require further assistance, please see the various Afrihost Help Support Channels available to you.
Am I signed into a long-term contract?
- No. Wireless LTE is offered on a month-to-month basis with no long-term commitments. You can upgrade, downgrade, or cancel as needed.
What is the cancellation policy for the Pure LTE packages?
Our normal Cancellation Policy applies to the Pure LTE packages.
- SIM + Device - Should you cancel your SIM + Device package, in less than 6 months from signup date, or your account falls into arrears, you will be charged a cancellation fee.
- SIM Only - The cancellation fee does NOT apply to SIM Only packages. These packages can be cancelled at any time before the 15th of the month.
What happens to my LTE device and Vodacom Wireless LTE SIM when I move to a new address?
- You can take your device and SIM card with you to your new location. If Vodacom coverage is available in the area, you will be able to connect without issues. However, please note that Afrihost cannot be held responsible if there is no network coverage at your new address.
Data
If you would like to know How to top up your Wireless LTE data please read our Help Centre article for assistance.
What if I already have an approved LTE device? Can I sign up for a SIM only package?
- Yes, a SIM only Vodacom Wireless LTE option is available. Ensure you have a compatible device.
Do you offer Unlimited LTE data packages?
- Yes, Uncapped LTE packages are available with Vodacom wireless LTE. Night Time data does NOT apply to uncapped packages.
How does Vodacom Wireless Uncapped LTE data work?
- 20Mbps Uncapped Vodacom Wireless LTE - Subject to a monthly threshold of 100GB. Once you’ve reached your monthly data limit, your connection speed will be limited to 4Mbps for the remainder of the month.
- 50Mbps Uncapped Vodacom Wireless LTE - Subject to a monthly threshold of 150GB. Once you’ve reached your monthly data limit, your connection speed will be limited to 8Mbps for the remainder of the month.
- 100Mbps Uncapped Vodacom Wireless LTE - Subject to a monthly threshold of 300GB. Once you’ve reached your monthly data limit, your connection speed will be limited to 10Mbps for the remainder of the month.
Any Terms and Conditions information presented in this article was correct at the time of publication. For the most up-to-date Terms and Conditions, please refer to our official Terms & Conditions page.
Can I upgrade or downgrade my package?
- Yes. All Fixed LTE packages can be upgraded or downgraded in ClientZone.
Package changes will only be effective on the 1st of the following month, regardless of when in the month the request is made or whether it is an upgrade or downgrade. This is a restriction from our providers.
Device
Can I use my own device with Wireless LTE?
- Only approved CAT6 devices will work with Vodacom Wireless LTE SIM Only packages on the Vodacom LTE Network.
- If you are using a new LTE SIM card with your own device, please visit see our Set Up Guide for instructions on how to get connected.
This range of devices includes:
- HUAWEI: 5G CPE PRO 2
- NOKIA: FastMile 5G Gateway 3.2
- ZTE: 5G CPE MC801A, 5G CPE G5T, 5G CPE G5TS
Please note that Vodacom Wireless will only work on the above approved devices. If you insert your SIM card into a device that has not been approved by Vodacom, your SIM card will be blocked, and you will lose internet access. You will then have to contact Afrihost Support to get your SIM card unblocked.
Do I need to set up my LTE device?
- If you have signed up for a SIM + Device package, Afrihost will preconfigure your new LTE device that is then shipped with your SIM card to you, so you do not need to change any settings.
You can read our helpful How to set up your Wireless Pure LTE Device article with easy instructions to help you configure your LTE device.
afrihost (Remember, all lower case and no spaces)
How many people can connect at the same time?
- You can connect up to 64 wireless devices concurrently to the included ZTE G5TS device. Please note that speeds may be affected by the number of devices connected to your modem.
Is there a delivery fee charged?
- SIM Only orders (Pure Wireless (MTN), Vodacom Wireless and Telkom Wireless) will be delivered FREE of charge.
- Vodacom Wireless SIM + Device orders will be delivered FREE of charge. The delivery fee is covered as part of the promotion. Please see our Terms & Conditions
Do I need to RICA my LTE SIM card?
If you would like to know How to manage your RICA information via ClientZone, please read our Help Centre article.
If you would like to know How to manage your RICA information in the Afrihost Mobile App, please read our Help Centre article.
What speeds can I expect on this network?
- The Vodacom network averages up to 35Mbps on 4G and up to 200Mbps on 5G.
